4–20 mA — The Most Important Signal in Instrumentation
Even in modern digital plants, one signal still dominates industrial automation ![]()
4–20 mA
Simple. Reliable. Industry standard.
What is 4–20 mA?
An analog current signal used to transmit process values
Examples:
Temperature
Level
Pressure
Flow
Why 4 mA to 20 mA?
4 mA = Live Zero
20 mA = Full Scale
0 mA means:
Wire break / fault detection
That’s the genius of 4–20 mA.
Why industry still uses it
Excellent noise immunity
Long-distance transmission
Simple & reliable
Easy troubleshooting
How it works
Transmitter measures process value
Converts it into 4–20 mA signal
PLC / DCS reads the value
Example
Tank Level Range = 0–100%
4 mA → 0%
12 mA → 50%
20 mA → 100%
Common mistakes
Confusing current loop with voltage signal
Wrong scaling in PLC/DCS
Poor grounding/shielding
Key concept
Voltage signals suffer more noise
Current signals are more stable for industries
Simple understanding
4–20 mA = Universal language between field instruments and control systems
4-20 mA Fundamentals Course
#Instrumentation #420mA #ProcessControl #IndustrialAutomation #PLC dcs #ControlSystems #Engineering #ProcessInstrumentation Automation ![]()
