A cooling water system is cooling a lube oil heat exchanger ___
A cooling water system is cooling a lube oil heat exchanger.
Cooling water system surge tank level is being measured using a differential pressure level detector that has been calibrated at the current water temperature in the tank.
A leak in the heat exchanger results in lube oil collecting in the surge tank.
Assuming that the temperature of the contents in the surge tank does not change, the indicated surge tank level will be __________ than actual surge tank level because lube oil is __________ than water.
A. higher; more dense
B. higher; less dense
C. lower; more dense
D. lower; less dense
