A cooling water system is operating at a steady-state flow rate of 400 gpm with 60 psid across the flow transmitter venturi. If cooling water flow rate is increased to 600 gpm, differential pressure across the ___
If cooling water flow rate is increased to 600 gpm, differential pressure across the flow transmitter venturi will be approximately…
A. 73 psid.
B. 90 psid.
C. 114 psid.
D. 135 psid.
Answer:D
