A diode whose negative resistance is dependent on the classical effects of phase shift introduced by the time lag between maximum field and maximum avalanche current, and by the transit time through the device ___
A diode whose negative resistance is dependent on the classical effects of phase shift introduced by the time lag between maximum field and maximum avalanche current, and by the transit time through the device.
A. Read diode
B. IMPATT diode
C. TRAPATT diode
D. all of the above
