A fire hose connected to the fire main is being used to suppress an elevated fire ___
A centrifugal firewater pump is operating to pressurize a fire main.
The pump takes suction from a water reservoir.
A fire hose connected to the fire main is being used to suppress an elevated fire.
Given:
  1. The eye of the pump impeller is located 5 feet above the reservoir water level.
  2. The pump has a design shutoff head of 120 feet.
  3. The required net positive suction head (NPSH) for the pump is 15 feet.
  4. The reservoir water temperature is 60°F.
At which one of the following elevations above the eye of the pump impeller will the fire hose spray nozzle first be unable to provide flow?
(Disregard all sources of head loss.)
A. 111 feet
B. 116 feet
C. 121 feet
D. 126 feet
