A neon lamp moved parallel to a twowire parallel transmission line will ___
A neon lamp moved parallel to a two wire parallel transmission line will glow at its brightest at which of the following points?
A. Maximum current points
B. Maximum voltage points
C. Maximum voltage and current points
D. Maximum and minimum current points
