A simple voltage-regulator whose output is the constant voltage drop developed across a zener diode conducting in the reverse breakdown region.
The regulator circuit consists of a zener diode in parallel with the load and an appropriate limiting resistor.
A. ordinary voltage regulator
B. zener voltage regulator
C. series voltage regulator
D. switching voltage regulator
