A standard squirrel-cage, AC induction motor will be provided with across-the-line starting and separate motor-starter running overload protection:
If the motor branch-circuit will be protected against high-level short-circuit/ground-fault overcurrent with time-delay fuses, the standard overrate is __________%; the NE Code®-maximum overrate (for HILA loads) is __________%.
A) 175; 225
B) 250; 300
C) 300; 400
D) 250; 400
Answer:A
