In Fully-welded Ball Valves, 3-piece design welded body reduces the number of potential leak paths.
Allows for reduction in weight, especially if the welded end version is selected.
The split body construction allows the use of forge materials in the various grades of CS, SS and high alloys, thus suitable for the most severe service conditions.
Compact design available with weld end/weld end connections.
Alternative option to the side-entry bolted body.
Typically used on gas transmission pipeline.
Available for all industries and applications.
