An AC generator is supplying an isolated electrical system with a power factor of 1.0 ___
An AC generator is supplying an isolated electrical system with a power factor of 1.0.
If generator voltage is held constant while real load (KW) increases, the current supplied by the generator will increase in direct proportion to the __________ of the change in real load.
(Assume the generator power factor remains constant at 1.0.)
A. cube
B. square
C. amount
D. square root
