An air-operated isolation valve requires 2,400 pounds-force applied to the top of the actuator diaphragm to open.
The actuator diaphragm has a diameter of 12 inches.
If control air pressure to the valve actuator begins to increase from 0 psig, which one of the following is the approximate air pressure at which the valve will begin to open?
A. 21 psig
B. 34 psig
C. 43 psig
D. 64 psig
