An inductor __________
A) is referred to as a current device because it stores electrical energy in an electromagnetic field that surrounds the coil of wire.
B) consists of two or more conductive plates with an insulating, non-conducting plate — dielectric — between them
C) Both is manufactured as a wound or spiral-wrapped coil of continuous wire which is normally mounted on an iron core & is referred to as a current device because it stores electrical energy in an electromagnetic field that surrounds the coil of wire.
D) is manufactured as a wound or spiral-wrapped coil of continuous wire which is normally mounted on an iron core
Answer:C
