An outside water storage tank is equipped with submerged heaters.
The heaters energize at minimum power when water temperature decreases to 48°F.
If water temperature continues to decrease, heater power will increase directly with the temperature deviation from 48°F until maximum power is reached at 40°F.
On cold days, the tank water temperature is usually maintained at about 44°F with the heaters energized at half power.
Which one of the following types of control is used in the heater control circuit to produce these characteristics?
A. Proportional only
B. Proportional plus integral only
C. Proportional plus derivative only
D. Proportional plus integral plus derivative
