As electronic circuit operates, its operating temperature changes which causes device parameters to change ___
As electronic circuit operates, its operating temperature changes which causes device parameters to change.
In op-amps, what do you call the change in input offset voltage due to the change in temperature?
A. input differential drift
B. input offset voltage drift
C. slew rate
D. PSRR
