A diesel generator (DG) is supplying both KW and KVAR to an electrical bus that is connected to an infinite power grid.
Assuming bus voltage does not change, if the DG voltage regulator setpoint is decreased slightly, DG KW will __________; and DG amps will __________.
A. remain the same; decrease
B. remain the same; remain the same
C. decrease; decrease
D. decrease; remain the same
