Because abnormal conditions such as short-circuit or ground-fault overcurrents can occur and effectively bypass the ___
Because abnormal conditions such as short-circuit or ground-fault overcurrents can occur and effectively bypass the load resistance, every circuit must be provided with a fuse or circuit breaker [or other overcurrent protection device(s)] to limit the current flow in the circuit to a safe level that will keep the circuit conductors from _______________.
A) none of the answers
B) overheating
C) heating
Answer:B
