You are part of the ground return path in the equipment-grounding system because the floor you are normally standing on or the metal enclosure you may be touching is part of the electrical equipment-grounding system of the building.
Because of this constant contact, you are on one side of the circuit at all times.
Electrical shock occurs when you complete a path by touching a live wire:
You either become the load as described earlier with touching both sides of the circuit, or your contact creates an alternate ground-fault path for circuit current.
A) True
B) False
Answer:A
