Because the electrical circuit or circuits you are working on are normally voltage-referenced to the ___
Because the electrical circuit or circuits you are working on are normally voltage-referenced to the ground, you should always remain insulated from any grounded source (surface).
If you are grounded, you will provide a path for current flow through yourself by touching any ungrounded (live) conductor in the electrical circuit at any point.
A) True
B) False
Answer:A
