Because the motor supply circuit may be configured as a three-phase AC, 3-wire corner-ground delta electrical-power distribution ___
Because the motor supply circuit may be configured as a three-phase AC, 3-wire corner-ground delta electrical-power distribution, supply leads L1 and L3 are normally interchanged with field leads T1 and T3.
Supply line L2, because it might be a grounded circuit conductor in the electrical power distribution system of the building or other structure, is left connected to T2 in the reversing of the rotor’s direction of rotation.
A) False
B) True
Answer:B
