Before taking actual voltage readings within the load or control circuit, ___ law should be used to determine if when the voltage is measured, it is the voltage expected in the circuit at the point of measure
Before taking actual voltage readings within the load or control circuit, ____________ law should be used to determine if when the voltage is measured, it is the voltage expected in the circuit at the point of measure.
A) Faraday’s
B) Ohm’s
C) Newton’s
D) none of the answers
Answer:B
