Check Valve — In piping and instrumentation, one small mistake can cause reverse flow… and that can damage equipment instantly.
That’s where a check valve becomes essential ![]()
What is a Check Valve?
A valve that allows flow in one direction only
Automatically prevents reverse flow
Operates without manual control
How it works
Fluid flows in the forward direction → Valve opens
Flow tries to reverse → Valve automatically closes
No operator, no signal… fully automatic
Why it is important
Protects pumps from reverse rotation
Prevents backflow contamination
Avoids pressure surges
Maintains process integrity
Where it is used
Pump discharge lines
Compressor systems
Water supply lines
Process pipelines
Types of check valves
Swing Check Valve
Lift Check Valve
Ball Check Valve
Wafer Check Valve
Simple understanding
Flow forward →
Allowed
Flow reverse →
Blocked
One small valve… but it protects the entire system.
#Instrumentation #ProcessControl #CheckValve #IndustrialAutomation #Piping #Engineering #OilAndGas #ProcessInstrumentation #Valves Automation ![]()
