Continuous Emission Monitoring system (CEMS) consists of particulate matter monitoring subsystem gaseous pollutant monitoring subsystem,flue gas parameters monitoring subsystem,system control and data acquisition and processing subsystem.It can monitor gases such as SO,NOX,O2, Dust, temperature, pressure, flow rate humidity etc.
The measured gas passes through sampling probe case for De-dusting,heating tube for sampling, then goes into the gas analysis module (DOAS) for analysis measurements.
It effectively solves the technical problems of dust and moisture interference on measurement, particularly in the case of low concentration measurements with an unparalleled advantage.
