Refer to the drawing of a venturi flow element in an operating cooling water system (see figure below).
A differential pressure detector measuring flow rate through the venturi will produce the highest flow rate indication if its high-pressure tap is connected at point _____; and its low-pressure tap is connected at point _____.
A. A; B
B. A; D
C. B; C
D. B; D
ANSWER: A.
