Electrical power applied to the solenoid coil is controlled by an array of normally-open or normally-closed ___
Electrical power applied to the solenoid coil is controlled by an array of normally-open or normally-closed contacts mounted on pushbutton or selector switches, pilot devices, such as limit, pressure, or temperature switches, or control relays within the _________________________ circuit.
A) signal or amplitude
B) power or frequency
C) none of the answers
D) signal or control
Answer:D
