Emergency Shutdown (ESD) logic design
:stop_sign: Emergency Shutdown (ESD) Logic Design — Explained Simply
In critical industries, one unsafe condition can become a disaster within seconds…
That’s why ESD logic is designed to protect the plant automatically :backhand_index_pointing_down:
:gear: What is ESD Logic?
:right_arrow: Logic used in an Emergency Shutdown System (ESD)
:right_arrow: Detects dangerous conditions and initiates safe shutdown actions
:right_arrow: Usually implemented in a Safety PLC / SIS
:brain: Main purpose of ESD
:fire: Protect people
:fire: Protect equipment
:fire: Prevent explosions & major accidents
:fire: Bring process to safe state
:rocket: Basic ESD logic flow
:satellite_antenna: Hazard detected
:down_arrow:
:brain: Safety PLC evaluates logic
:down_arrow:
:high_voltage: Shutdown action executed
:magnifying_glass_tilted_left: Typical ESD inputs
:small_blue_diamond: High-High Pressure
:small_blue_diamond: High Temperature
:small_blue_diamond: Gas Detection
:small_blue_diamond: Fire Detection
:small_blue_diamond: Manual ESD Push Button
:high_voltage: Typical ESD outputs
:small_orange_diamond: Close ESD valves
:small_orange_diamond: Trip pumps/compressors
:small_orange_diamond: Shut fuel supply
:small_orange_diamond: Activate alarms
:factory: Important ESD design concepts
:green_circle: Fail-safe philosophy
:right_arrow: De-energize to trip
:green_circle: Voting logic
:right_arrow: 1oo2 / 2oo3 architectures
:green_circle: Redundancy
:right_arrow: Dual CPUs, redundant I/O
:green_circle: Independent operation
:right_arrow: Separate from BPCS/DCS
:warning: Critical engineering practices
:white_check_mark: Minimize common cause failures
:white_check_mark: Proper cause & effect matrix implementation
:white_check_mark: Sequence of Events (SOE) logging
:white_check_mark: SIL-based design verification
:bullseye: Key takeaway
:backhand_index_pointing_right: ESD logic is not for process control
:backhand_index_pointing_right: It is designed for safe shutdown during dangerous conditions
:brain: Normal PLC → Runs the process
:stop_sign: ESD Logic → Stops the process safely
#ESD #ProcessSafety #FunctionalSafety #SafetyPLC #SIS #Instrumentation Automation #ControlSystems #Engineering #IEC61511 :rocket:
