Emergency Stop (E-Stop)
:stop_sign::police_car_light: EMERGENCY STOP (E-STOP): The Button Designed to Stop Dangerous Motion Quickly! :gear::factory:
Imagine a machine suddenly becomes dangerous:
:gear: Rotating equipment jams
:construction_worker: A person enters a hazardous area
:fire: A machine begins behaving abnormally
:collision: Mechanical failure occurs
The operator needs a way to immediately initiate the emergency stopping function.
:backhand_index_pointing_right: That is the purpose of an Emergency Stop (E-Stop).
:small_blue_diamond: What is an Emergency Stop?
An Emergency Stop is a manually operated emergency control used to initiate a function intended to stop hazardous motion or a dangerous process condition as quickly as necessary to reduce risk.
It is commonly implemented using a red actuator with a yellow background, although exact requirements depend on the applicable machinery standard and design.
:stop_sign: E-Stop = Human-initiated emergency action to reduce an immediate hazard
:gear: How Does an E-Stop Work?
A typical machine arrangement may be:
E-Stop Pushbutton
:down_arrow:
:electric_plug: Safety Relay / Safety PLC
:down_arrow:
:high_voltage: Contactor / Drive Safe-Torque-Off / Actuator
:down_arrow:
:stop_sign: Machine stops
When the E-Stop is pressed:
:red_circle: Button actuated
:down_arrow:
:brain: Safety circuit detects the request
:down_arrow:
:stop_sign: Hazardous motion is stopped using the defined stopping method
:factory: Example: Motor-Driven Pump
Suppose an operator sees a dangerous mechanical condition.
They press:
:stop_sign: E-STOP
The safety system may:
:right_arrow: Remove the motor run command
:right_arrow: Activate the required stopping function
:right_arrow: Isolate energy where required
:right_arrow: Indicate the emergency-stop status
The exact shutdown sequence depends on the machine/process risk assessment.
:electric_plug: E-Stop in Industrial Automation
E-Stops may interact with:
:gear: PLC
:shield: Safety PLC
:locked_with_key: Safety relay
:high_voltage: Motor contactor
:control_knobs: VFD
:counterclockwise_arrows_button: Servo drive
:police_car_light: ESD system
For a VFD-driven motor, for example, the emergency-stop function may use a safety-rated stop function such as Safe Torque Off (STO) where appropriate.
:warning: E-Stop vs Normal Stop
These are not the same.
:green_circle: Normal Stop
Used during routine operation:
Stop command β†’ Controlled shutdown β†’ Equipment stops
:red_circle: Emergency Stop
Used when an emergency situation requires rapid action:
E-Stop β†’ Safety function β†’ Hazardous motion/process is stopped according to the designed emergency-stop strategy
An E-Stop should not be treated as the normal operating method for stopping equipment.
:vs_button: E-Stop vs ESD
E-Stop:
:stop_sign: Usually a manually initiated emergency stop associated particularly with machinery or equipment.
ESD:
:police_car_light: A broader emergency shutdown function used in process facilities to bring equipment/process sections to a defined safe state.
An E-Stop signal may initiate an ESD action in some process facilities, but they are not automatically synonymous.
:counterclockwise_arrows_button: Does Pressing E-Stop Automatically Restart the Machine?
Normally, no.
After the emergency condition is cleared:
:stop_sign: E-Stop remains actuated/latched
:down_arrow:
:unlocked: E-Stop is reset
:down_arrow:
:magnifying_glass_tilted_left: Safety conditions verified
:down_arrow:
:play_button: A separate restart command is required
This prevents an unexpected automatic restart.
:warning: Important Safety Principle
An E-Stop is not a substitute for risk assessment or other protective measures.
The required emergency-stop function depends on:
:small_blue_diamond: Hazard identification
:small_blue_diamond: Risk assessment
:small_blue_diamond: Stopping time
:small_blue_diamond: Stored energy
:small_blue_diamond: Machine/process design
:small_blue_diamond: Applicable standards
:small_blue_diamond: Required safety performance
:bullseye: Interview Question
What is an Emergency Stop (E-Stop)?
:backhand_index_pointing_right: An E-Stop is a manually initiated emergency control function designed to stop hazardous motion or a dangerous process condition as quickly as necessary to reduce risk.
:light_bulb: Remember:
:green_circle: Normal Stop β†’ Routine operation
:stop_sign: E-Stop β†’ Emergency intervention
:police_car_light: ESD β†’ Emergency process shutdown
An E-Stop doesn’t simply mean β€œturn the power off.” The stopping method must be selected according to the hazard and safety design.
#EmergencyStop #EStop #SafetyPLC #MachineSafety #FunctionalSafety #PLC #IndustrialAutomation #VFD #STO #ESD #SIS #ProcessSafety #Instrumentation #ControlSystems #AutomationEngineer :stop_sign::gear::factory:
