Error-rate damping is considered to be better than friction or friction- clutch damping because of which of the following characteristics of the error-rate damping system?
A. A small change in the error signal causes maximum damping
B. A large change in the error signal causes maximum damping
C. A small error signal of short duration will not be damped
D. A large error signal of short duration will not be damped
