For a unijunction transistor (UJT) to witch ON ___
A. the base 1 voltage should be greater than the peak voltage
B. the base 2 voltage should be greater than the peak voltage
C. the emitter voltage should be greater than the peak voltage
D. the voltage between the emitter and base 1 should be greater than the peak voltage when emitter being more positive
