For any series circuit; If the circuit has two breaking points or two openings, the voltage can still be measured at the point of ___, but the open-circuit voltage can only be read across the ___ connection of the two breaks:
If the circuit has two breaking points or two openings, the voltage can still be measured at the point of ____________, but the open-circuit voltage can only be read across the ____________ connection of the two breaks:
There has to be circuit, device, or component ________________ between the two points of reference or measure for the voltmeter and the power supply.
A) supply; parallel; discontinuity
B) none of the answers
C) series; continuity; supply; series
D) supply; series; continuity
Answer:D
