Gear Box is used to decrease the speed and to increase the torque
Gear Box is used to decrease the speed and to increase the torque.
A. True
B. False
In the majority of cases it is true that the gear reducer’s function is to lower the speed (RPM) and increase the Torque.
But there are instances where the standard motor speeds are not enough for the use, like in centrifuges, and there you use the gear reducer inverted, so the outlet speed is greater than the motors and you sacrifice a bit of torque.
