High-voltage disconnect switches are used to ___
High-voltage disconnect switches are used to…
A. adjust the output voltage range from a main power transformer.
B. protect bus feeder breakers by opening upon bus short-circuit faults.
C. provide equipment isolation under no-load conditions.
D. bypass and isolate an electrical bus while maintaining the downstream buses energized.
