If a mercury-filled bulb is mechanically linked to the clock spring, then a change in temperature will cause a ___ of the bulb: the switch is either open or closed when a change in temperature is sensed
If a mercury-filled bulb is mechanically linked to the clock spring, then a change in temperature will cause a ________________________ of the bulb: the switch is either open or closed when a change in temperature is sensed.
A) unstable
B) none of the answers
C) tilt or leveling
Answer:C
