If the motor branch-circuit will be protected against high-level short-circuit/ground-fault overcurrent with an inverse-time circuit breaker, the standard overrate is __________%; the NE Code-maximum overrate (for HILA loads) is restricted to __________%, if the motor FLC is 100 amps or less, and __________%, if the motor FLC is over 100 amps.
A) 400; 250; 300
B) 300; 300; 300
C) 250; 400; 300
D) 250; 400; 400
Answer:C
