If the overhead lighting is controlled from a single location, the SPST toggle switch must be wired in ___, ahead of the ___ lighting load, in the ___ supply of the branch circuit
If the overhead lighting is controlled from a single location, the SPST toggle switch must be wired in ____________ , ahead of the ____________ lighting load, in the __________________ supply of the branch circuit.
A) series; parallel; grounded
B) parallel; parallel; ungrounded
C) series; series; ungrounded
D) series; parallel; ungrounded
Answer:D
