If the overload relay is ___, the toggle switch latches in when the switch is flipped or snapped ON
If the overload relay is __________, the toggle switch latches in when the switch is flipped or snapped ON.
The switch contacts are being held closed against ____________ ____________.
A) none of the answers
B) reset; string tension
C) start; spring tension
D) reset; spring tension
Answer:D
