If the percentage impedances of the two transformers working in ___
If the percentage impedances of the two transformers working in parallel are different, then
A. transformers will be overheated
B. power factors of both the transformers will be same
C. parallel operation will be not possible
D. parallel operation will still be possible, but the power factors at which the two transformers operate will be different from the power factor of the common load
