If the rotor is not turning (during start-up or under locked-rotor conditions), the motor’s stator and rotor circuits now function as a transformer:
The rotor circuit frequency is ___________ to the AC supply frequency in the stator circuit.
The __________________ of the primary and secondary electromagnetic fields is at its maximum, which causes the induced secondary voltage to be at its _______________ .
_______________ voltage equates to maximum current in the shorted secondary rotor circuit.
The impedance reflected into the primary is _______________ , which causes maximum current flow in the primary or stator circuit.
The stator and rotor circuits are generating large amounts of ___________ within the electric motor.
A) equal; interaction; maximum; Maximum; minimal; heat
B) equal; interaction; maximum; Maximum; minimal; heat
C) maximum; Maximum; minimal; heat; equal; interaction
D) none of the answers
Answer:A
