If you exceed the frequency limitations of ___
If you exceed the frequency limitations of your voltmeter, which of the following results is likely?
A. The meter will be destroyed
B. The circuit under test will be damaged
C. The measurement will be inaccurate
D. The meter will indicate average voltage
