In a closed loop system, the process to be controlled is an integrating process with transfer function l/2s.
The controller proposed to be used in an integral controller with transfer function 1/T1s.
When a step change in set point is applied to such a closed loop system, the controlled variable will exhibit
A. overdamped response.
B. underdamped response.
C. undamped response.
D. unstable response.
