In a feedback loop, what is the primary purpose of comparing PV with SP inside controller logic continuously?
A. Signal scaling
B. Noise removal
C. Sensor Configuration
D. Error Calculation
View Answer:
Correct Answer: D. Error Calculation
Explanation (Control Loop Concept)
In any feedback control loop, the controller continuously compares:
- SP (Setpoint) → Desired value
- PV (Process Variable) → Actual measured value
The difference between these two is called error.
Mathematically:
Error=SP−PV
This comparison is not optional — it is the core function of the controller.
Why is this comparison important?
- The controller uses this error signal to decide:
- Whether the process needs correction
- How much correction is required
- Based on this error, the controller adjusts the output (like valve position, motor speed, etc.)
In simple terms:
- If PV ≠SP → error exists → controller acts
- If PV = SP → error = 0 → no correction needed
Real-Time Operation Insight
A feedback controller:
- Continuously monitors PV
- Compares with SP
- Generates an error signal
- Uses that error to drive corrective action
This is exactly how systems maintain stability and accuracy.
Why Other Options Are Wrong
- A. Signal scaling → Done in input conditioning, not main control logic
- B. Noise removal → Done using filters, not by SP-PV comparison
- C. Sensor Configuration → Setup task, not real-time control function
Final Takeaway
The continuous comparison of PV and SP exists only to generate error, which drives the entire control action.
