In a PID loop, what is the setpoint (SP)?
Question:
Options:
A) Measured value
B) Desired value
C) Output value
D) Error value
:white_check_mark: Correct Answer: B) Desired value
The Setpoint (SP) is the desired or target value that the process variable (PV) should reach and maintain.
Examples:
  • Desired temperature = 150°C
  • Desired pressure = 5 bar
  • Desired flow = 100 m³/hr
The controller continuously compares:
Error = SP - PV
If SP changes, the controller adjusts the output to move PV toward the new target.
A) Measured value → That is the Process Variable (PV).
C) Output value → That is the Controller Output (CO).
D) Error value → Error is the difference between SP and PV.
:fire: Quick Memory Tip
  • SP = Target
  • PV = Actual
  • CO = Action
  • Error = SP − PV
