In the wiring diagram of a 9-lead, 230/460-volt, ___-configured, 3-phase AC, squirrel-cage induction motor for 460-volt operation, six connections are required
In the wiring diagram of a 9-lead, 230/460-volt, __________ -configured, 3-phase AC, squirrel-cage induction motor for 460-volt operation, six connections are required.
With the three power-supply line identified as L1, L2, and L3 and the motor winding lead / jumper terminals identified as T1 through T9: L1 should be connected to T1; L2 should be connected to T2; L3 should be connected to T3; T4 should be connected to T7; T5 should be connected to T8; and T6 should be connected to T9.
A) Neither delta nor wye
B) delta
C) Both delta and wye
D) wye
Answer:C
