Interlocks vs Trips vs Permissives
Interlocks vs Trips vs Permissives โ€” Explained Simply
These three terms are everywhere in PLC, DCS, and SIS systemsโ€ฆ
But many engineers still confuse them :backhand_index_pointing_down:
:green_circle: Permissive
:right_arrow: Condition required to START equipment
:backhand_index_pointing_right: โ€œCan I start the machine?โ€
Example:
:small_blue_diamond: Lube oil pressure healthy
:small_blue_diamond: Cooling water available
:small_blue_diamond: Valve in correct position
:white_check_mark: If all conditions are OK โ†’ Equipment can start
:yellow_circle: Interlock
:right_arrow: Prevents wrong or unsafe operation during running condition
:backhand_index_pointing_right: โ€œShould this action be blocked?โ€
Example:
:small_blue_diamond: Prevent motor start if valve closed
:small_blue_diamond: Prevent pump operation at low tank level
:high_voltage: Mainly used to avoid equipment/process damage
:red_circle: Trip
:right_arrow: Immediate shutdown during dangerous condition
:backhand_index_pointing_right: โ€œStop NOW for safety!โ€
Example:
:fire: High-high pressure
:fire: High temperature
:fire: Fire & gas detection
:police_car_light: Equipment/system shuts down automatically
:brain: Simple comparison
:green_circle: Permissive โ†’ Allows START
:yellow_circle: Interlock โ†’ Prevents wrong action
:red_circle: Trip โ†’ Forces SHUTDOWN
:factory: Real example โ€” Pump System
:white_check_mark: Permissive โ†’ Tank level healthy โ†’ Pump allowed to start
:warning: Interlock โ†’ Discharge valve closed โ†’ Pump start blocked
:police_car_light: Trip โ†’ Motor overload โ†’ Pump trips immediately
:backhand_index_pointing_right::backhand_index_pointing_right: Video Lessons:
:bullseye: Key takeaway
:one: Permissive = Start permission
:two: Interlock = Operational protection
:three: Trip = Emergency shutdown
:backhand_index_pointing_right: Before Start โ†’ Permissive
:backhand_index_pointing_right: During Operation โ†’ Interlock
:backhand_index_pointing_right: During Danger โ†’ Trip
#Instrumentation #PLC #SIS #ProcessSafety Automation #ControlSystems #IndustrialAutomation #Engineering dcs #FunctionalSafety :rocket:
