Inverter relay-logic requires two control lines or rungs of a ladder diagram ___
Inverter relay-logic requires two control lines or rungs of a ladder diagram.
The relay-contact inversion is technically of the NO control switch or other switching contacts for control of the relay solenoid coil in one control line.
The open switch is considered to be the input to the inverter, whereas the load side of the NC control-relay contacts in the second rung of the ladder is the wired-inverter’s output.
A) True
B) False
Answer:A
