Limited to a single set of NC control-relay contacts: running overload protection poses a problem with a reversing motor-starter simply because the reversing circuit consists of only one other 3-pole contactor.
The single set NC overload-relay contacts must be wired in series with both directional power-contactor solenoids to provide overload-overcurrent protection for the electric motor in either direction of rotation.
If the control circuit is _____________________, the common side of the two directional power-contactor solenoids must be parallel-connected to the common circuit conductor.
The single set of NC overload-relay contacts must be placed in series with the stop section of the control circuit for the reversing electromagnetic motor starter.
This must occur ____________ the split for the two separate directional start circuits.
A) none of the answers
B) biased; before
C) grounded; before
D) grounded; after
Answer:C
