Logic Test in DCS and ESD system
A signal reaching the DCS or ESD system correctly does not necessarily mean the system will perform the correct action.
The next question is:
β€œWhen the required conditions occur, does the configured logic produce the correct output?” :bullseye:
That is the purpose of a Logic Test.
:small_blue_diamond: What is a Logic Test?
A logic test is a functional test used to verify that the configured control or safety logic produces the intended result for defined input conditions.
In simple terms:
Inputs β†’ Logic β†’ Outputs
We apply or simulate specific input conditions and verify that the system responds according to the approved logic diagrams, Cause & Effect, control philosophy, and functional requirements.
:desktop_computer: Logic Test in DCS
Consider a cooling-water pump:
Low Flow β†’ DCS Logic β†’ Pump Start
The logic may be designed so that:
  • Low flow detected
  • Standby pump is available
  • Auto mode is selected
  • Start command is generated
During the logic test, different combinations are simulated to verify:
:white_check_mark: Correct input recognition
:white_check_mark: Correct AND/OR conditions
:white_check_mark: Correct timers
:white_check_mark: Correct interlocks
:white_check_mark: Correct permissives
:white_check_mark: Correct sequence
:white_check_mark: Correct output command
Example
Suppose a pump can start only when:
Tank Level > 30% AND Suction Valve Open AND Pump in AUTO
The logic test should verify not only the TRUE condition, but also the FALSE conditions.
If any required permissive is missing:
:cross_mark: Pump should not start.
:police_car_light: Logic Test in ESD System
ESD logic testing is more safety-critical.
Consider a high-high pressure shutdown:
PT β†’ ESD Input β†’ Safety Logic β†’ Solenoid β†’ Shutdown Valve
Suppose the Cause & Effect requires:
2oo3 Pressure Voting β†’ ESD Trip β†’ Close SDV
The logic test verifies that the configured safety logic behaves exactly as specified.
For example:
:green_circle: One transmitter high β†’ No trip
:green_circle: Two transmitters high β†’ Trip
:green_circle: Three transmitters high β†’ Trip
The actual voting philosophy depends on the approved SIS design.
:magnifying_glass_tilted_left: What is Checked During Logic Testing?
:one: Input Conditions
Are the correct input tags being used?
:two: Logic
Are the configured:
AND / OR / NOT / Voting / Latching
functions correct?
:three: Timers
Are:
:stopwatch: Time delays
:stopwatch: On-delay
:stopwatch: Off-delay
configured correctly?
:four: Interlocks & Permissives
Does the equipment respond correctly when permissives are:
:white_check_mark: Present
or
:cross_mark: Absent?
:five: Outputs
Does the correct output operate for the specified input condition?
:six: Latching & Reset
For shutdown functions:
:police_car_light: Trip β†’ Latch β†’ Reset
The test should verify that the trip remains latched until the required reset conditions are satisfied.
:vs_button: DCS Logic Test vs ESD Logic Test
DCS Logic Test ESD Logic Test
Tests control/sequencing logic Tests safety/shutdown logic
Interlocks & permissives Trips, voting & shutdown logic
Start/stop sequences Cause & Effect actions
Control outputs Safety outputs
Process control focus Risk reduction/protection focus
Based on control philosophy Based on SIS safety requirements
:warning: Very Important
A logic test is not the same as a loop test.
:electric_plug: Loop Test:
Verifies the signal path and functional response from field β†’ system β†’ output/final element as defined by the test scope.
:brain: Logic Test:
Verifies that the configured logic makes the correct decision for defined input conditions.
:bullseye: Simple Interview Answer
What is a Logic Test in DCS/ESD?
:backhand_index_pointing_right: A logic test verifies that the configured DCS or ESD logic responds correctly to specified input conditions and generates the intended outputs according to the approved control philosophy, Cause & Effect, and functional requirements.
:light_bulb: Remember:
:electric_plug: Loop Test = Is the signal path working correctly?
:brain: Logic Test = Is the programmed decision correct?
:police_car_light: ESD Logic Test = Will the safety system take the correct protective action when the specified trip conditions occur?
#LogicTest dcs #ESD #SIS #SafetyInstrumentedSystem #CauseAndEffect #FunctionalSafety #SIL #Instrumentation #PLC #ProcessControl #IndustrialAutomation #Commissioning #ControlSystems #OilAndGas #InstrumentationEngineer :police_car_light::gear::factory:
