List of Standards
ISO 91-1: 1992
Petroleum measurement tables – Part 1: Tables based on reference temperatures of 15 degrees C and 60 degrees F
ISO 91-2: 1991
Petroleum measurement tables – Part 2: Tables based on a reference temperature of 20 degrees C
ISO 1998-6: 2000
Petroleum industry – Terminology – Part 6: Measurement
ISO 2186:2007
Measurement of fluid flow in closed conduits – Connections for pressure signal transmissions between primary and secondary elements
ISO 2714: 1980
Liquid hydrocarbons – Volumetric measurement by displacement meter systems other than dispensing pumps
ISO 2715: 1981
Liquid hydrocarbons – Volumetric measurement by turbine meter systems
ISO 2909: 2002
Petroleum products – Calculation of viscosity index from kinematic viscosity
ISO 3170: 2004
Petroleum liquids - Manual sampling
ISO 3171: 1988
Petroleum liquids – Automatic pipeline sampling
ISO 3675: 1998
Crude petroleum and liquid petroleum products - Laboratory determination of density - Hydrometer method
ISO 3733: 1999
Petroleum products and bituminous materials – Determination of water - Distillation method
ISO 3734: 1997
Petroleum products - Determination of water and sediment in residual fuel oils - Centrifuge method
ISO 3735: 1999
Crude petroleum and fuel oils - Determination of sediment - Extraction method
ISO 3838: 2004
Crude petroleum and liquid or solid petroleum products - Determination of density or relative density - Capillary-stoppered pyknometer and graduated bicapillary pyknometer methods
ISO 3993: 1984
Liquefied petroleum gas and light hydrocarbons - Determination of density or relative density - Pressure hydrometer method
ISO 4124: 1994
Liquid hydrocarbons – Dynamic measurement – Statistical control of volumetric metering systems
ISO 4257: 2007
Liquefied petroleum gases – Method of sampling
ISO 4267-2: 1988
Petroleum and liquid petroleum products - Calculation of oil quantities - Part 2: Dynamic measurement
ISO 5024: 1999
Petroleum liquids and liquefied petroleum gases - Measurement - Standard reference conditions
ISO 5167-1: 2003
Measurement of fluid flow by means of pressure differential devices inserted in circular cross-section conduits running full – Part 1: General principles and requirements
ISO 5167-2: 2003
Measurement of fluid flow by means of pressure differential devices inserted in circular cross-section conduits running full – Part 2: Orifice plates
ISO 5167-3: 2003
Measurement of fluid flow by means of pressure differential devices inserted in circular cross-section conduits running full – Part 3: Nozzles and Venturi nozzles
ISO 5167-4: 2003
Measurement of fluid flow by means of pressure differential devices inserted in circular cross-section conduits running full – Part 4: Venturi tubes
ISO 5168:2005
Measurement of fluid flow - Procedures for the evaluation of uncertainties
ISO 6296: 2000
Petroleum products – Determination of water – Potentiometric Karl Fischer titration method
ISO 6326-1: 2007
Natural gas – Determination of sulfur compounds – Part 1: General introduction
ISO 6551: 1982
Petroleum liquids and gases – Fidelity and security of dynamic measurement – Cabled transmission of electric and/or electronic pulsed data
ISO 6974-1: 2000 & ISO/FDIS 6974-1: 2011
Natural gas - Determination of composition with defined uncertainty by gas chromatography - Part 1: Guidelines for tailored analysis
ISO 6974-2: 2001
Natural gas - Determination of composition with defined uncertainty by gas chromatography - Part 2: Measuring-system characteristics and statistics for processing of data
ISO/FDIS 6974-2: 2011
ISO 6974-3: 2000
Natural gas - Determination of composition with defined uncertainty by gas chromatography - Part 3: Determination of hydrogen, helium, oxygen, nitrogen, carbon dioxide and hydrocarbons up to C8 using two packed columns
ISO 6974-4: 2000
Natural gas - Determination of composition with defined uncertainty by gas chromatography - Part 4: Determination of nitrogen, carbon dioxide and C1 to C5 and C6+ hydrocarbons for a laboratory and on-line measuring system using two columns
ISO 6974-5: 2000 & ISO/NP 6974-5: 2010
Natural gas - Determination of composition with defined uncertainty by gas chromatography - Part 5: Determination of nitrogen, carbon dioxide and C1 to C5 and C6+ hydrocarbons for a laboratory and on-line process application using three columns
ISO 6974-6: 2002
Natural gas - Determination of composition with defined uncertainty by gas chromatography - Part 6: Determination of hydrogen, helium, oxygen, nitrogen, carbon dioxide and C1 to C8 hydrocarbons using three capillary columns
ISO 6976: 1995
Natural gas – Calculation of calorific values, density, relative density and Wobbe index from composition
ISO/TR 7066-1: 1997
Assessment of uncertainty in calibration and use of flow measurement devices - Part 1: Linear calibration relationships
ISO 7066-2: 1988
Assessment of uncertainty in the calibration and use of flow measurement devices - Part 2: Non-linear calibration relationships
ISO 7278-1: 1987
Liquid hydrocarbons - Dynamic measurement - Proving systems for volumetric meters – Part 1: General principles
ISO 7278-2: 1988
Liquid hydrocarbons - Dynamic measurement – Proving systems for volumetric meters – Part 2: Pipe provers
ISO 7278-3: 1998
Liquid hydrocarbons - Dynamic measurement - Proving systems for volumetric meters – Part 3: Pulse interpolation techniques
ISO 7278-4: 1999
Liquid hydrocarbons - Dynamic measurement - Proving systems for volumetric meters - Part 4: Guide for operators of pipe provers
ISO 8222:2002
Petroleum measurement systems - Calibration – Temperature corrections for use when calibrating volumetric proving tanks
ISO 8310: 1991
Refrigerated light hydrocarbon fluids - Measurement of temperature in tanks containing liquefied gases - Resistance thermometers and thermocouples
ISO 8943: 2007
Refrigerated light hydrocarbon fluids – Sampling of liquefied natural gas – Continuous and intermittent methods
ISO 9000: 2005
Quality management systems – Fundamentals and vocabulary
ISO 9001: 2008
Quality management systems - Requirements
ISO 9004: 2009
Managing for the sustained success of an organization - A quality management approach.
ISO 9029: 1990
Crude petroleum – Determination of water – Distillation method
ISO 9030: 1990
Crude petroleum - Determination of water and sediment - Centrifuge method
ISO 9300: 2005
Measurement of gas flow by means of critical flow Venturi nozzles
ISO/TR 9464: 2008
Guidelines for the use of ISO 5167:2003
ISO 9770: 1989
Crude petroleum and petroleum products – Compressibility factors for hydrocarbons in the range 638 kg/m3 to 1 074 kg/m3
ISO 9951:1993
Measurement of gas flow in closed conduits – Turbine meters
ISO 10005: 2005
Quality management systems - Guidelines for quality plans
ISO/TR 10013: 2001
Guidelines for quality management system documentation
ISO 10307-1: 2009
Petroleum products - Total sediment in residual fuel oils - Part 1: Determination by hot filtration
ISO 10307-2: 2009
Petroleum products - Total sediment in residual fuel oils - Part 2: Determination using standard procedures for ageing
ISO 10336: 1997
Crude petroleum – Determination of water – Potentiometric Karl Fischer titration method
ISO 10337: 1997
Crude petroleum – Determination of water – Coulometric Karl Fischer titration method
ISO 10715: 1997
Natural gas – Sampling guidelines
ISO 10723:2002
Natural gas – Performance evaluation for on-line analytical systems
ISO 10790: 1999
Measurement of fluid flow in closed conduits – Guidance to the selection, installation and use of Coriolis meters (mass flow, density and volume flow measurements)
ISO/PRF TR 11583: 2011
Measurement of wet gas flow by means of pressure differential devices inserted in circular cross-section conduits
ISO 11631: 1998
Measurement of fluid flow – Methods of specifying flowmeter performance
ISO 12185: 1996
Crude petroleum and petroleum products - Determination of density - Oscillating U-tube method
ISO 12213-1: 2006
Natural gas – Calculation of compression factor – Part 1: Introduction and guidelines
ISO 12213-2: 2006
Natural gas – Calculation of compression factor – Part 2: Calculation using molar-composition analysis
ISO 12213-3: 2006
Natural gas – Calculation of compression factor – Part 3: Calculation using physical properties
ISO/DIS 12242 (1)
Measurement of fluid flow in closed conduits - Ultrasonic meters for liquid
ISO/TR 12767: 2007
Measurement of fluid flow by means of pressure differential devices – Guidelines on the effect of departure from the specifications and operating conditions given in ISO 5167
ISO 12937: 2000
Petroleum products – Determination of water – Coulometric Karl Fischer titration method
ISO 13443: 1996
Natural gas - Standard reference conditions
ISO/DTR 13587 (1)
Three statistical approaches for the assessment and interpretation of measurement uncertainty
ISO 14111:1997
Natural Gas – Guidelines to traceability in analysis
ISO 14532:2001
Natural Gas Vocabulary
ISO 15112: 2011
Natural gas – Energy determination
ISO 15212-1: 1998
Oscillation-type density meters – Part 1: Laboratory instruments
ISO 15212-2: 2008
Oscillation-type density meters – Part 2: Process instruments for homogeneous liquids
ISO/TR 15377: 2007
Measurement of fluid flow by means of pressure-differential devices – Guidelines for the specification of orifice plates, nozzles and Venturi tubes beyond the scope of ISO 5167
ISO 15970: 2008
Natural gas – Measurement of properties – Volumetric properties: density, pressure, temperature and compression factor
ISO 15971: 2008
Natural gas – Measurement of properties – Calorific value and Wobbe index
ISO/IEC 17021: 2011
Conformity assessment – Requirements for bodies providing audit and certification of management systems
ISO/IEC 17025: 2005
General requirements for the competence of testing and calibration laboratories
ISO 17089-1: 2010
Measurement of fluid flow in closed conduits - Ultrasonic meters for gas - Part 1: Meters for custody transfer and allocation measurement
ISO/DIS 17089-2
Measurement of fluid flow in closed conduits - Ultrasonic meters for gas – Part 2: Meters for industrial applications
ISO 19011: 2002
Guidelines for quality and/or environmental management systems auditing
ISO 19739: 2004
Natural gas – Determination of sulfur compounds using gas chromatography
ISO 20765-1: 2005
Natural gas – Calculation of thermodynamic properties – Part 1: Gas phase properties for transmission and distribution applications
ISO 20815: 2008
Petroleum, petrochemical and natural gas industries - Production assurance and reliability management
ISO 21748: 2010
Guidance for the use of repeatability, reproducibility and trueness estimates in measurement uncertainty estimation
ISO 23874: 2006
Natural gas – Gas chromatographic requirements for hydrocarbon dewpoint calculation
ISO/TS 29001: 2010
Petroleum, petrochemical and natural gas industries - Sector-specific quality management systems - Requirements for product and service supply organizations
CEI 60751: 2008
Industrial platinum resistance thermometers and platinum temperature sensors
ISO 80000-1: 2009
Quantities and Units – Part 1 : General
ISO/IEC Guide 28: 2004
Conformity assessment – Guidance on a third-party certification system for products
ISO/IEC Guide 98-1: 2009
Uncertainty of measurement – Part 1: Introduction to the expression of uncertainty in measurement
ISO/IEC NP Guide 98-2
Uncertainty of measurement - Part 2: Concepts and basic principles
ISO/IEC Guide 98-3: 2008
Uncertainty of measurement - Part 3: Guide to the expression of uncertainty in measurement (GUM:1995)
ISO/IEC Guide 98-3 Sup1: 2008
Propagation of distributions using a Monte Carlo method.
ISO/IEC NP Guide 98-4
Uncertainty of measurement - Part 4: Role of measurement uncertainty in conformity assessment
ISO/IEC NP Guide 98-5
Uncertainty of measurement - Part 5: Applications of the least-squares method
ISO/IEC Guide 99: 2007
International vocabulary of metrology - Basic and general concepts and associated terms (VIM)
API MPMS 4.1: 2009
Proving system - Introduction
API MPMS 4.2: 2003
Proving system - Displacement provers
API MPMS 4.4: 2010
Proving system - Tank provers
API MPMS 4.5: 2005
Proving system - Master Meter provers
API MPMS 4.6: 2008
Proving system - Pulse interpolation
API MPMS 4.7: 2009
Proving system - Field Standard Test Measures
API MPMS 4.8: 2007
Proving system - Operation of Proving Systems
API MPMS 5.1: 2008
General Considerations for Measurement by Meters
API MPMS 5.2: 2005
Measurement of Liquid Hydrocarbons by Displacement Meters
API MPMS 5.3: 2009
Measurement of Liquid Hydrocarbons by Turbine Meters
API MPMS 5.4: 2005
Accessory Equipment for Liquid Meters
API MPMS 5.5: 2010
Fidelity and Security of Flow Measurement Pulsed-Data Transmission Systems
API MPMS 5.6: 2008
Measurement of Liquid Hydrocarbons by Coriolis Meters
API MPMS 5.8: 2005
Measurement of Liquid Hydrocarbons by Ultrasonic Flowmeters Using Transit Time Technology
API MPMS 7: 2007
Temperature Determination
API MPMS 8.1: 2006
Manual Sampling of Petroleum and Petroleum Products
API MPMS 8.2: 2010
Automatic Sampling of Petroleum and Petroleum Products
API MPMS 8.3: 2010
Standard Practice for Mixing and Handling of Liquid Samples of
API MPMS 8.4: 2009
Standard Practice for Sampling and Handling of Fuels for Volatiltiy Measurement
API MPMS 9.1: 2005
Standard Test Method for Density, Relative Density (Specific Gravity), or API Gravity of Crude Petroleum and Liquid Petroleum Products by Hydrometer Method
API MPMS 9.2: 2007
Standard Test Method for Density or Relative Density of Light
Hydrocarbons by Pressure Hydrometer
API MPMS 9.3: 2008
Standard Test Method for Density, Relative Density, and API Gravity of Crude Petroleum and Liquid Petroleum Products by Thermohydrometer Method
API MPMS 10.1: 2007
Standard Test Method for Sediment in Crude Oils and Fuel Oils by the Extraction Method
API MPMS 10.2: 2007
Standard Test Method for Water in Crude Oil by Distillation
API MPMS 10.3: 2008
Standard Test Method for Water and Sediment in Crude Oil by the Centrifuge Method (Laboratory Procedure)
API MPMS 10.4: 2010
Determination of Sediment and Water in Crude Oil by the Centrifuge Method (Field Procedure)
API MPMS 10.5: 2005
Standard Test Method for Water in Petroleum Products and
Bituminous Materials by Distillation
API MPMS 10.6: 2004
Standard Test Method for Water and Sediment in Fuel Oils by the Centrifuge Method (Laboratory Procedure)
API MPMS 10.7: 2006
Standard Test Method for Water in Crude Oils by Potentiometric Karl Fischer Titration
API MPMS 10.8: 2010
Standard Test Method for Sediment in Crude Oil by Membrane
Filtration
API MPMS 10.9: 2010
Standard Test Method for Water in Crude Oils by Coulometric Karl Fischer Titration
API MPMS 11.1: 2004
Temperature and Pressure Volume Correction Factors for Generalized Crude Oils, Refined Products, and Lubricating Oils
API MPMS 11.2.2: 2007
Compressibility Factors for Hydrocarbons: 0.350–0.637 Relative
Density (60 °F/60 °F) and –50 °F to 140 °F Metering Temperature
API MPMS 11.2.2M: 2007
Compressibility Factors for Hydrocarbons: 350–637 Kilograms per Cubic Meter Density (15 °C) and –46 °C to 60 °C Metering Temperature
API MPMS 12.2.1: 2009
Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volume Correction Factors, Part 1-Introduction
API MPMS 12.2.2: 2010
Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volumetric Correction Factors, Part 2-Measurement Tickets
API MPMS 12.2.3: 2009
Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volumetric Correction Factors, Part 3-Proving Reports
API MPMS 12.2.4: 2009
Calculation of Petroleum Quantities Using Dynamic Measurement Methods and Volume Correction Factors, Part 4-Calculation of Base Prover Volumes by Waterdraw Method
API MPMS 12.2.5 :2009
Calculation of Petroleum Quantities – Section 2 – Calculation Using Dynamic Measurement Methods and Volumetric Correction Factors, Part 5 – Calculation of Base Prover Volume by Master Meter Method
API MPMS 13.1: 2011
Statistical Concepts and Procedures in Measurement
API MPMS 13.2: 2011
Statistical Methods of Evaluating Meter Proving Data
API-MPMS 15: 2007
Guidelines for Use of the International System of Units (SI) in the Petroleum and Allied Industries.
API MPMS 20.1: 2006
Allocation Measurement
API MPMS 21.2: 2004
Electronic Liquid Volume Measurement Using Positive Displacement and Turbine Meters
API MPMS TR 2570: 2010
Continuous on-line Measurement of Water In Petroleum (Crude Oil and Condensate)
API MPMS RP 86: 2005
Recommended Practice for Measurement of Multiphase Flow
API MPMS Publ 2566 : 2004
State of the Art Multiphase Flow Metering
AGA Report Nr 3-1: 2009
API MPMS 14.3.1
Orifice Metering of Natural Gas Part 1: General Equations & Uncertainty Guidelines
AGA Report Nr 3-2: 2006
API MPMS 14.3.2
Orifice Metering of Natural Gas Part 2: Specification and Installation Requirements
AGA Report Nr 3-3: 2009
API MPMS 14.3.3
Orifice Metering of Natural Gas Part 3: Natural Gas Applications
AGA Report Nr 3-4: 2006
API MPMS 14.3.4
Orifice Metering of Natural Gas Part 4: Background, Development Implementation Procedure
AGA Report Nr 5: 2009
Natural Gas Energy Measurement
AGA Report Nr 7: 2006
Measurement of Natural Gas by Turbine Meter
AGA Report Nr 8: 1994
Compressibility Factor of Natural Gas and Related Hydrocarbon Gases
AGA Report Nr 9: 2007
Measurement of Gas by Multipath Ultrasonic Meters
AGA Report Nr 10: 2003
Speed of Sound in Natural Gas and Other Related Hydrocarbon Gases
AGA Report Nr 11: 2003
Measurement of Natural Gas by Coriolis Meter
ASTM D341-03
Standard Test Method for Viscosity-Temperature Charts for Liquid Petroleum Products
ASTM D 1945-03: 2010
Standard Test Method for Analysis of Natural Gas by Gas Chromatography
NFOGM 2001
Handbook of uncertainty calculation, Ultrasonic Fiscal Gas Metering Station
NFOGM 2003
Handbook of uncertainty calculation, Fiscal Orifice Gas and Turbine Oil Metering Station
NFOGM Handbook 2005
Handbook of Water Fraction Metering
Handbook Revision 2: 2005
Handbook of Multiphase Flow Metering
NS-EN 1776: 1999
Gas supply systems - Natural gas measuring stations – Functional requirements
OIML R117-1: 2007
Dynamic measurement systems for liquids other than water
22, 52
OIML R137-1: 2006
Gas meters – Part 1: Requirements
OIML R140: 2007
Measuring systems for gaseous fuel
