Most equipment technical manuals contain ___
NOTE : You need to take a critical voltage reading, but you do not have a high impedance meter available.
Instead, you connect two lower impedance meters in series and place them across the component in question.
you add the readings shown on the two meters to get your measurement.
Most equipment technical manuals contain voltage charts.
For which of the following purposes are they used?
A. To list the equipment’s power supplies
B. To list the input power requirements of the equipment
C. To provide handy reference guides for calculating voltage drops across fixed impedances
D. To list correct voltages at major test points
