Prior to starting a positive displacement pump, the discharge valve should be open to ___
Prior to starting a positive displacement pump, the discharge valve should be open to…
A. prevent rupturing the pump casing.
B. limit the pump motor starting time.
C. ensure the pump casing fills by backflow.
D. reduce pressure fluctuations in the discharge piping.
