Redundancy in Safety PLC systems
:shield: Redundancy in Safety PLC systems:
In safety systems, one failure should not stop protection.
That’s why industries use redundancy :backhand_index_pointing_down:
:gear: What is Redundancy?
:right_arrow: Using multiple components performing the same function
:right_arrow: Backup available if one component fails
:right_arrow: Improves safety, reliability & availability
:brain: Simple idea
:backhand_index_pointing_right: One device fails β†’ Another continues protection
:rocket: Where redundancy is used
:small_blue_diamond: CPUs / Processors
:small_blue_diamond: Power supplies
:small_blue_diamond: Communication networks
:small_blue_diamond: I/O modules
:small_blue_diamond: Sensors & final elements
:magnifying_glass_tilted_left: Common redundancy architectures
:green_circle: 1oo2 β†’ One out of Two
:green_circle: 2oo3 β†’ Two out of Three
:green_circle: TMR β†’ Triple Modular Redundancy
:backhand_index_pointing_right: Used based on required SIL level
:factory: Why redundancy is important
:high_voltage: Eliminates single point of failure
:high_voltage: Improves fault tolerance
:high_voltage: Maintains system operation during failure
:high_voltage: Increases safety integrity
:warning: Important point
:cross_mark: More hardware alone β‰  Better safety
:white_check_mark: Proper design + independence is critical
:brain: Example
:right_arrow: Dual Safety PLC CPUs running together
If one CPU fails:
:white_check_mark: Backup CPU continues operation
:white_check_mark: Safety function remains active
:bullseye: Key takeaway
:one: Redundancy improves reliability
:two: Helps achieve higher SIL levels
:three: Prevents dangerous system failures
:backhand_index_pointing_right: Redundancy = Backup protection for critical systems
SIS Videos
#SafetyPLC #FunctionalSafety #SIS #Redundancy #ProcessSafety #Instrumentation Automation #ControlSystems #Engineering #IEC61511 :rocket:
